BeoSound 1 & 2 next gen announced!
Just had a demo - works as expected!
To be released in september.
It is a hardware revison - so kind of new product.
The ‘old’ version will be available too.
Perfect timing. I had just been contemplating replacing my kitchen BeoSound 1 with a BeoSound 2 for sound from my kitchen TV/BeoSystem 3 -- since the BeoSound 1 has no line-in.
I wonder if the circle of dots is functional or just the google branding (same as the lights on their speakers ) ?
From B&O's press release : Both have five microphones to listen to your voice commands with a control panel on top to let you swipe for next or previous tracks, turn it to adjust the volume plus four buttons you can program to launch things like calendar, weather, radio, music playlists via Google Assistant compatible services.
‘I wonder if the circle of dots is functional’
The ‘dots’ wil be used for presets (like those on a BROne) later on.
@chucky: what’s better in Alexa concerning home automation? Only Crestron compatibility or more?
