BeoRemote One, SKY+ HD
Hi All
My SQY Q box has died so I have temporarily replaced with an older HD box on my BV14 and have a BeoRemote one.
I have setup the Thompson SHY HD MKII PUC, which works ok but there MUST be an easier way to record than having to navigate to "record" through the list button using the menus on the BR1?
Have you tried pressing menu then the number 8
This is the only way. B&O did move the record function to the end of the list, so by pressing up it appears first.
