I just set up a Beosound Stage with a C9 at my parents house.
It works just fine with the BeoRemote One over BT to control the TV, and I can get the light commands over IR to work if I switch to "Beo4 audio" mode.
I managed to store "light" to one of the MyButtons but only in IR mode, and it takes some multiple button presses to switch between IR and BT mode.
Is there any way to store a IR-light command on a MyButton in BT mode. Or a way to quickly switch between IR and BT mode, (or if you like, between "Stage" and "Beo4 audio" mode)?
To clarify this is for controlling a LC2 directly over IR, no MLGW or other equipment involved.
Any suggestions appreciate.
Thanks in advance
//Goran
