Hi
I have bought a 2nd hand Beoremote One. I am trying to use it as a Beo4. I have selected Beo4 Audio on the menu but when I press radio, or cd etc... nothing happens. The screen works perfectly. I did check if the IR Transmitters light up using my phone camera but they don't. Does this mean that it is faulty or am I doing something incorrectly. I have another Beoremote which I can get to work perfectly. Just wondering if there is an IR setting I don't know about.
