Beoremote one BT and two audio source
It is possible to use a Beoremote One with 2 audio sources (e.g core & M5).
Or does one need 2 remotes?
It needs to be a Bluetooth version of the BeoRemote One (BT), but then yes, you can use 1 remote with several devices.
In the list menu of the remote, you can select which device to control. It is not possible to control both simultaneously, you need to switch between devices in the remote.
