Beoremote Halo can now control ML devices!
beojeff wrote:
I no longer have any ML slave rooms.
What do you mean with ML slave rooms?
Quite impressive 9 BLC!
My predominant system is NL/B&o ControlLink with 4 BLC all set as ASlaves with a total of 4 ML Audio systems connected 1 BS5 Encore and 1 BG4000.
So there are no speakers connected to any ML/older product. That way one have almost complete control of the ML Audio systems in the NL/B&o Controllink environment . As explained before I can choose the CD to play on a BS9000.
I no longer have any link room speakers or TVs that are part of an ML network. I.e., no Beolab 3500 or Beovision in slave mode that is reliant on a separate Audio or Video Master. All devices are now either natively NL or joined to NL via that device's dedicated NL/ML Converter.
A question that relies more to you BLI and Masterlink products…. Do you still have full access to your ML through your NL/ML converters from your BLI in the same way as with MLGW
Carolpa wrote:
until I chanced the setting of one of my BLC from ASlave to VMaster (and back). Suddenly they appeared!
Worked for me too, thanks! Now I can join CD from BS9000 to Stage in multiroom, as beojeff described only with the Halo. I love it!
Carolpa wrote:
the ML sources are shown, but not the BLC line in.
Oh! So that means if I connect Beogram 4004 to a BLC line in it won't be controllable by Halo? Hopefully I can still multiroom it through the B&O app at least?
But would it show on Halo if I add BLI, despite the fact it is on BLC line in?
for the moment only in combination with BLI
You would have to create a macro in the BLI to make a new button for the line-in source.
I've sent an email to beocare pointing out to them some of these -- such as the lack of volume control and lack of the full video control screen.
