Hi all,
I don't know why the 2.0 version has got problems in finding the TV's in some situations.
But let me explain the different powersaving / startup modes.
Quick start timer:
if enabled the TV stays ON all the time. It is fully accessible via network and the app / Beo4 only needs to send a "SOURCE" command to fire up the screen.
Wake on (W)Lan:
If quick start timer is disabled and WOL is enabled the TV will shutdown if STANDBY was pressed. The only part that will still be active is the network controller. It will listen for the "magic WOL package". The remote app will send out this specific package and the TV will start booting immediately. It will take nearly the same time as if you activate it via e.g. the Beo4. If the app detects that the TV is fully accessible via network it asks you for which source should be activated.
Quick start and WOL disabled
In this mode the TV can only be activated via incoming IR commands. The TV will consume least power in standby.
BR,
BeoMotion.
