Wouldn't it be great if B&O offered some sort of adapter for existing TV's. I know there is the ML Gateway but I don'y have an AMX, Crestron or other system so it seems a bit overkill. I have a MK5 BeoVision 7-40 which I consider to be reasonably up to date and would love to control it by my iPad. I am very interested to see this new TV as it may prompt a little desire to upgrade!!
BeoRemote App for iPad released
It now also "works" on the Beoplay V1 but this is what I get:
The app works just fine.
It now also "works" on the Beoplay V1 but this is what I get: link ðŸ˜
On other Apps I see that behaviour when my network access has a wrong password.
What iPad generation are you running ?
Shouldn't be too difficult to make. If someone with a BV11 or V1 can capture the data stream between the Ipad and the TV from when starting the app to the menu is fully populated I could give it a try. I have the beoremote app connecting to alaptop, but it can only recognize volume, mute and standby functions as the menus are created based the equipment connected and I need the data stream to understand what the TV is sending to the app.The easiest option would probably be to make a simple converter box to and put it between the BeoRemote app and a lintronic box. It also looks like http://www.mammutbox.com/ is coming out with a lower cost alternative to MLGW, so an option would be to user that box and the BeoLink app instead of the BeoRemoteWouldn't it be great if B&O offered some sort of adapter for existing TV's. I know there is the ML Gateway but I don'y have an AMX, Crestron or other system so it seems a bit overkill. I have a MK5 BeoVision 7-40 which I consider to be reasonably up to date and would love to control it by my iPad. I am very interested to see this new TV as it may prompt a little desire to upgrade!!
