Just visit iTunes ... 🙂
EDIT: works only for BEOVISION 11 as the description in the iTunes Store says ...
done :)
done :)
now what 🙂 says ...
PRODUCT NOT FOUND
PLEASE ENSURE THAT THE TV IS
ON THE SAME NTWORK
[FIND]
Sorry, but you'll need a BV 11 ...
As the description in the iTunes Store says "... for BeoVision 11"
so it is not REALLY free then 😁
pity ... I hoped it would talk to my ATVs
Good one Ed :-)so it is not REALLY free then
Did they add an in-app purchase opportunity? 1 BV11 - 10.000 euro. Accept?
Dear friend,
😁 We are both old enough to know that NOTHING on EARTH is REALLY FREE!
Sometimes fun will cost your life, sometimes your freedom and in the very best case
just some money ... LOL
As the Beoplay V1 has the exact same engine as the BV11, the future software update of the V1 should give the opportunity to control it with the BeoRemote app...
As the Beoplay V1 has the exact same engine as the BV11...
"Exact" - I seriously 🙂 doubt !!
Based on the same engine, YES !!
Maybe in the future, if B&O wants to PLAY a bit more ...
