Beoremote 1 BT Amazon Netflix
Hi
I am trying to attach Apple TV to the MyButton, of which I only have one.  I’ve looked up the manual on line but it’s all about the one with 4 MyButtons, and the instructions simply do not work with my remote
Any help would be very welcome
Just navigate to your AppleTV and press one of the 4 MyButtons for a couple of seconds. You'll get a message onscreen that the source has been added tot the button.
You can only add a source and speaker groups to the MyButtons; so just for example your Apple TV. You will still need to go to Netflix on your AppleTV.. The AppleTV Netflix app cannot be added
Karel.
The BeoRemote One with Netflix and Amazon direct access buttons works just like the one with 4 MyButtons.
As
Thanks. Very simple to do. But the manual makes things sound a lot more complicated than that. Go onto lists, settings, advanced, buttons etc. Etc
Sorted. Thanks
