BeoRemote 1
Can you make a Remote one go to a STB source by default instead of going to the digital tuner first on a BeoVision Eclipse? I don’t use the tuner.
Hallo expoman,
Yes that is no problem,
You have to go to settings, and there you can choose what the button TV is going to wake up.
When I press TV on mine it starts up the Apple TV.
Good morning,
You have to set the priority in the Eclipse menus. The remote will be then adjusted automatically.
Regards,
Jean
