Beoportal - what is it?
Hi all
ive Been having unresolved issues with all my multiroom products now for months, very little help or advice from support and the dealer. Just noticed in the BeoTool app that all devices are showing red with beoportal not ready.
can anyone help me with what this is, or how it can be resolved?
Are you signed in to your Bang & Olufsen account in your B&O app?
Are all your products set up under your B&O account?
Yes, all signed in correctly. Have removed and re added all my products and still getting the same across all of them. Beoportal not ready.
I’m sorry, James. That’s what did the trick for me when I had this issue last year.
I’ve checked my products in BeoTool and it says that the portal is online, at least from the U.K.
The only other thing I can suggest is an internet issue, or your firewall blocking the port on which the portal communicates, but I don’t know which one that is.
Hopefully someone else can offer a solution.
Lawrence
I was having trouble last year and couldn't figure out the problem.  I eventually put all my devices on static IP addresses with designated google DNS (8.8.8.8) and everything started working fine.  The problem was probably my firewall or my PiHole DNS filter.
Anyway, perhaps try setting a static IP address and known-good DNS?
I was having trouble with BeoPortal last year and couldn't figure out the problem.  I eventually put all my devices on static IP addresses with designated google DNS (8.8.8.8) and everything started working fine.  The problem was probably my firewall or my PiHole DNS filter.
Thank you fir your reply, sadly my limited IT knowledge means it’s of little practical use to me! Is that something I should be able to do myself?
I would not worry too much about « beoportal not ready status » as long as your products do the job, can be software upgraded and appeared correctly in the B&O App.
The BeoTool app has not been updated since ages and I personally have this status regularly for several of my products, not always the same, and without any impact on anything.
It's certainly something you can do yourself if you don't mind learning a little about networking.  I know I'd have trouble teaching my 81-year-old father to do it because he has no patience with technology.  But if you don't mind learning something new, it's pretty straightforward and I'd be happy to teach you.
Can you be more specific about the troubles you're having?  Best to make sure that the problems are somehow network-related (though I suspect they are.)
I’m getting regular dropouts when using tune in, sound vanishes, but the products appear to still be playing in the app. Switching to another station and back again solves it. I’m at a loss and so is the support desk. After seeing beoportal in red on the app I thought this may help if I fixed it.
thank you so much for offering to help.
