Beoport vs AirTunes - strange finding
Hi.
I have the following setup:
IMac 27" from 2010.
Beoport connected to ML net
BV8-40 with Apple Tv2
BV8-32 with Apple Tv1
BS3200 next to the 8-40
BL2000
I use Beoport for distribution of N.Music throughout my house. The sound is OK but sounds thin. By chance I tired to stream music from my iMac to the Apple Tvs using AirTunes. The sound then comes via HDMI (8-40) or Scart Audio (BV8-32) to the TV sets. The sound is much much more powerful and rich. Going back to N.Music ( with my constellation I can switch during the same song) the sound is thin again...
How can this be? Should not ML distribution be of at least same Quality? It cannot be the apple DAC, as ATV2 has no and 8-40 uses it's own.
Any ideas are very welcome!
Thanks,
Heribert
Did you calibrate the volume?
Yes I did. Volume was same level.
Wireless radio from airtunes vs headphone jack from the mac.  Disappointed, but not surprised.
I would agree if not the internal DAC of ATV1 is also much better than Beoport. Equalizer was off in all cases.
IT IS THE DAC of your IMac 27" you are using to transmit music via an
analogue line-out of your apple to analogue the-line in of your BeoPort (2x3,5mm stereo jack) .
The USB cable between BeoPort and computer is only used to remote control your MAC
by your ML-components.
Understand. But what about the ATV1 which is connected to 8-32 via analog connection? Is the DAC in ATV1 so much better? Cannot believe this.
I know nothing about the quality of anyone's internal DAC, but I DO know that the speaker-level output of a mac (and most other computers and mp3 players) is not so great.  Depending on what outputs you have available on the mac, you might convert one of them to a 3.5 stereo output and input that to the BeoPort.  It should be fantastic on lossless material.  Too bad, but BeoPort had a lot of good points and (obviously) not enough "management" backing to take full advantage of them.
Maybe ...
All I can tell is - a WMA lossless send from my vintage IBM-PC via BeoPort > ML-system >
BV7 and then beeing distributed via PowerLink to a pair of BLb5s (= all analogue chain)
sounds just a LITTLE BIT less "detailed", less "open", less "dynamic" than the ORIGINAL CD
coming from a BSd 9000 DIRECTLY via SPDIF (= fully digital chain) to the BLb5s.
PS: Using the VERY SAME A8 earphones, a 192 file ripped from a CD on my BeoSound 2
sounds much better than the same 320 file on my iPhone ...
PPS: the iPhone is a GREAT CELLPHONE
PPPS: und ganz besonders mag ich Äpfel wenn sie "grün, saftig und steirisch sind" 😂
We have a similar set up with the ATV2 connected to the Avant, and then the Avant connected via ML to the rest of the house. The sound is fantastic and with wireless connection, we can play from any of the computers or the iPad2.  We are just getting ready to add an Airport Express to the BS9000  via A. Aux. All of this is much easier to use than the Beoport, which has been a bit cranky without really great sound, plus we can now use our iPad2 with the B&O setup.
I should mention that we had VERY good luck with ATV2 and the Avant by using a convertor. The signal for audio and video is wonderful.
