Hi dear members,
Have a Beoport which I want to control with my Beo4 remote. What IR eye (puck) type do I need since I think there are several types?
Thanks! Leslie
Hi dear members,
Thanks! Leslie
The BeoPort puck has no inscriptions; the BeoLink Active/Wireless puck has the words "PLAY", "TIMER" and the symbols "v" and "^" on it.
Thanks Elephant! So one type only and that type I can use?
Well there are at least two types of pucks.
But only the one with the blank face is the BeoPort's.
I am not sure of their part numbers ... sorry.
I have checked my PDFs including the Service Manual but there are no clues there.
Perhaps the PRODUCT section of Beoworld or Beotech might have them.
hi there
i got a spare unit here currently minus lead but i have one of those too a simple task to resolder the lead back in place - if interested pm me etc
tony s
Tony, check PM!
Leslie
Is
Hard to tell from the fuzzy photo, but it looks like the "eye" does not have writing nor a light ... so it could very well be the addition you are looking for !
Thanks "mate"!🤒
Leslie
Is link (found on Ebay UK) something I could use for controlling my Beoport (Beo4)
Difficult to see on that picture. As you know there are two different link-eye models.
The correct one for BeoPort has partnumber 8087030 and has 2 unlabled buttons. The standard IR eye has 4 labled buttons (timer, up, down and play)
