Hi all,
I have the following setup:
A BeoPort with an IR eye, connected to my PC (set to BeoLink Option 6) and connected to a BeoLink Passive amp via PowerLink, additionally I have an Ouverture connected to the BeoPort via MasterLink. This all works fantastic with the BeoPort software installed to listen to my PC or N.Music selected, or access the Ouverture Radio/CD/Tape. Also works nicely with my Beo4 remote (old version with SAT, AV, CD, VTAPE, ATAPE) where I have the A.TAPE2 added to the list, so able to select N.Music remotely as well.
Now I'd like to extend this to another room, so I have a second BeoLink Passive amp with an IR eye in the other room. I thought I can connect it via a MasterLink cable and all should work ok with my Beo4. It works with Radio/CD/Tape, but I can't get sound for PC or N.Music.
Can someone please help what am I doing wrong or what do I need to make the second amp work with N.Music (if possible at all), additional question if there's a way to select the PC source via Beo4 in the second room somehow?
Thanks, Zoltan
