Beoport
I am having trouble installing Beoport 4.83 on my new Vista Ultimate (32 bit)PC. Having turned off the firewall and running the Beoport program as an Adminstrator, the software runs until it gets to the point of installing the USB driver.
The program then hangs, and Windows comes up with a search box in an attempt to try and find a driver. There are a couple of options - automatic (recommended) or browse.
I have tried both options without success (browsing to Windows\system32\drivers) and it then says it cannot find a driver and aborts the installation.
Has anybody else had this problem and found a workaround?
Can't think of a good reason - no doubt there is a conflict in the operating system - there is a new version S/W 5.00 which could be worth a try though. I used to have similar problems trying to get B&O software to work with my PC - now have a Mac !
I had same problem back when the product changed name to BeoPort.
My BeoLink PC (the old name for BeoPort) had to go to the dealer.
They changed something (probably the whole main board), and it have been working ever since.
I am not using Mac.
/MikaelB
I have installed the new Beoplayer from B&o and it works perfectly until i have shut down my computer and startet it the next day, then it says that there is a problem and it windows are searching for a solution.
The only way i can get it to work again are if i reinstall it and then it works again.
It is only Boeplayer and Net radio that doesn't work all the other links work perfectly
Anyone knows what could be wrong.
Jorgen
