BeoPlayer App updated 1.2.4 released
It just says bug fixes for iOS 5...
Thanks !
Download & update worked fine.
Had a mild panic attack when there was a slight glitch when I first invoked Airplay to the ATV2 but after that it was fine - not that I had noticed any iOS5 bugs anyway !
PS all my stations are still in the list; switching between them without problems ... just the 5 second buffering period.
Can also confirm the clock now works for me which it didn't do on the previous version (on iOS 5 devices)
I'm glad they worked the clock problem, but that really seemed to take a long time to address.
These are all of the resolved issues
1.Must press PLAY twice after PAUSE
2.BeoPlayer app shuts down when selecting music from the iPhone
3.Clock time does not synchronise with system time while staying on same "Clock" screen
4.Alarm cannot be stopped on iPhone 4S
None of the BBC radio stations are working :-(
Radio 2 is all I use(d) it for.
I checked on my iPad and looked under "United Kingdom" in Browse mode and found under "B" a bunch of them ranging from BBCArabic to "BBC World Service News" that included "BBC Radio 2"
I then did some testing (by the way use Search to find "BBC" rather than the long winded way I used first) and found that:
  1. the BBC stations I tested went "buffering", "retry", buffering", retry" until I got bored and did not play
  2. the exception was BBC World Service
  3. interesting, I had similar problems with a number of other UK stations, and
  4. (I know this does not make sense with internet protocols as opposed to shortwave radio) the were all faint (low volume)
  5. whereas other stations around the globe were good volume with good "signal" (connectivity) including the Netherlands, Germany, France, Italy, and Portland, Oregan
So I hope you have better luck being "closer" to the source
That is exactly what I meant by not "working"
I tried BBC 2 via Safari on my iPhone and it worked immediately. My BBC widget on my iMac also still works so the problem must be with the App itself. I have also reloaded it, just in case. Lets hope the station list can be updated wihout B&O having to submit to to Apple for review.
Tim
