Hi there!
Can anybody tell me if you get the wireless antenna and the PUC Cable with your V1 in the Box or do I have to buy them separately?
Lenny
Hi there!
Lenny
Hi Lenny,
The wireless antenna is in the box. The PUC cable you have to buy separately.
hfat
OK. That sounds OK. Does anybody know if this PUC Cable is a standard product or if they have to order it?
Mine came with a double PUC cable for two external units. I told the dealer I had an Apple TV before they delivered the tv so it might be because of that
Hi LennyAll BeoVision's are now supplied with a single PUC cable. If you need to control more products then ask your dealer and this can be supplied as an accessory.Hi Lenny, The wireless antenna is in the box. The PUC cable you have to buy separately. hfat
Therefore, my new V1 which will be delivered on Friday, should have a single PUC cable. Which is enough. I just want to connect an Apple TV
Mine (from November 2013) came with the Antenna (which I don't need) in the box.
My dealer told me that this is/was about to change - you will have to order that seperately in the future.
And it came with a single-wired PUC cable.
As I needed 2xPUC, I got an additional double-wired from the dealer.
There are two PUC ports on the V1 (32"), so you need at least one double-wired cable, if you want to control more than two external devices.
Lets see if the wireless Antenna is included or not... I will report as soon as I have my V1 at home on Friday
Mine came with both if you need a double PUC I'm sure you dealer will send you one
Ours came with a Tyko antenna which I found after the installer left and I called the store . They said they didn't know what it's for and it must be the installers and he forgot it. Could this be the wireless antenna ?
