BeoPlay V1 'dead' after software update
Thank you, I'll try it once more.
Hi RuudI had a similar issue with an Avant that wouldn't take a sw update wired or wireless plus for some reason all of the DVB channels were lost. I had to do a complete factory reset and do a new installation, then it all came good. Like your V1 it was only displaying BANG & OLUFSEN whilst updating, I left it to update which took about 20 minutes because the set hadn't updated for about a year!Dear fellow forum members, Yesterday I performed a software update on my BeoPlay V1 using the USB stick method. I used this method because the V1 kept giving an network error, as well wired as wireless. The procedure seemed te be successful as I saw the progress bar actually move. BUT..... after the update my V1 won't start up anymore. I only see the BANG & OLUFSEN text in the right corner, but the V1 won't react on any remote control command at all. When I shut the V1 the screens blanks, but the green power LED keeps slowly blinking. Anyone any idea what could be a solution here?? Ruud Hornman
Hi w5bno123,
did you perform the factory reset yourself or did you have to contact your dealer?
B&O always recommend to do upgrades by internet, in your case it did not work. Must be problems with the networkcard from the beginning.
Glad things worked out in a good manner for you, by replacing the mainboard hopefully under warranty. Enjoy your TV!
Are software updates done automatically? or are people prompted to do them? hopefully B&O put a block to the update on the early V1
I can imagine there will be a lot of people going to have this same issue :(
On the avant it's not auto. You can set it to auto if you wantAre software updates done automatically? or are people prompted to do them? hopefully B&O put a block to the update on the early V1 I can imagine there will be a lot of people going to have this same issue :(
