BeoPlay V1 'dead' after software update
Dear fellow forum members,
Yesterday I performed a software update on my BeoPlay V1 using the USB stick method. I used this method because the V1 kept giving an network error, as well wired as wireless. The procedure seemed te be successful as I saw the progress bar actually move.
BUT..... after the update my V1 won't start up anymore. I only see the BANG & OLUFSEN text in the right corner, but the V1 won't react on any remote control command at all. When I shut the V1 the screens blanks, but the green power LED keeps slowly blinking.
Anyone any idea what could be a solution here??
Ruud Hornman
Did you remove the power completely from your V1, and connect it again after a minute.
I did remove the power, but maybe not long enough, so I will try that again.
No, unfortunately no solution.
As soon as I plug in the cord again, the power LED starts blinking and choosing TV on my remote control gives me only the BANG & OLUFSEN text.
Is there a PINCODE on the V1? If so, you might try to start entering numbers of the PINCODE at the B&O screen?
I never used a pincode myself. Is there a chance that that the software update has introduced one? And is there a default 'factory pincode"?
I was just grasping at straws when I thought of the possibility of a PINCODE. I highly doubt that the SW update would have suddenly introduced one.
Have you unplugged the V1 and left it disconnected to the mains for a while (ie. >30min). I'm just wondering if it needs a true "reset" and the only way to be sure is to leave it off the mains for longer than a few moments.
Thank you for participating in my frustration!
I have tried leaving the set unplugged for an extensive time (over 1 hour) and I have tried to leave it on with the B&O screen. In the latter case the V1 simply turns off automatically after some time and shows the blinking green LED again.
Sounds like the software didn't take.
Try to factory reset?
That is what I was trying to do, but I really haven't got a clue how to do that! Any idea?
