My new Beoplay V1 40" is connected to a pair of Beolab 9. I have installed the CI+ module for HDTV. However, the main reason why I use my set-up is for audio - mainly streaming from Spotify through Airplay on my Apple TV (3rd generation) and the occasional FLAC file (through media player).
To listen to music, I need stereo sound with switched-off center speaker.The V1 does not switch off the center speaker at P.MUTE, like my old BV8 used to do. So, the only way to achieve a switched off center speaker is to create a speaker group with the V1 speakers switched off. That was easy. However, I have two problems here that the B&O dealer did not know about and that the install guy could not solve either.
1. setting any new speaker group as default is only possible for source "radio", but not for the Apple TV (on HDMI 1)
Apparently, the only way to enable this speaker group is to use the menu, navigate through numerous options and then enable the newly created speaker group manually every single time. That is a terrible thing, because 90% of the time I need only audio. So, for now, I changed the default TV speaker group to have a switched off center speaker, thereby reducing the V1 to a vastly overpriced screen only.
2. even with the new speaker group enabled and with "music" sound mode, the sound is still weird
Even with the above mentioned settings, music still sounds like it is surround signal passed on to a stereo set-up. I read something about speaker roles, but I did not quite grasp it. I may be able to change some settings on the ATV, too, but does anybody know how to achieve the stereo sound I am used to with my BL9?
To summarize: I am looking to listen to high quality stereo music from ATV on Beolab 9 with the v1. I would greatly appreciate your help!
