Hello
I plan to buy a v1 40 from 2012 for a guest room. Some people seem to have problem with overheating in 2020.
Could you please tell me after 8 years you are still enjoying yours ?
olivier
Hello
olivier
Indeed I enjoy mine/a 32”.
Not my main tv - but used for regular tv/news, a lot of YT wieving (don’t need a big screen for that mostly), radio and music listening….full 5.1 setup.
A tv that I would miss, if it was not there.
And…..I’d probably buy another one as replacement, if it had to go.
The problem, that I have heard of, is a leaking battery - mine did not suffer (yet).
If you buy one, see to that it is fully working and have that battery replaced.
Hi MM
Thanks for your answer. I don't know there was a battery inside, what is its function ?
I am technical not that much into this (other forum members probably are).
From what I know it is some kind of backup batteri, that in some cases may leak and cause damage to the mainboard (which is rather expensive to replace, if possible).
And I don’t know of any specific event, that may cause this - if at all.
Every good B&O seller here (in Denmark) will replace this battery, before selling.
May it be because he will have to sell it with a warranty or just to be sure.
And I can’t say how many V1’s are infected - maybe not many??
Anyway, if I were to buy a V1, it would be something, that I would be concerned about.
In the end - buying from private will always include a risk - these tv’s are old now/could be almost 9 years old.
As I wrote….I still love and use my V1.
Hi, similar to MM here in that not only do I love and enjoy my V1-32 but if it packed in I would definitely seek to replace it with the same set if there was still one available. It’s a fantastic tv and I love the design of it. In my house, it is my kitchen tv but I do still have it on most days as I spend a lot of time in my kitchen. I have had it since 2016 and it works beautifully and perfectly every time and I’ve never experience an issue. Hope this helps. A fantastic tv with a great picture too I think. Cheers, Simon.
Thanks all for your answer.
I hesitate between a bv 11 46 or v1 40.
