Beoplay V-1 software update
I find that the bass are too present since the update on my BV11.
Am I dreaming ?
Am I dreaming ?
Can't say I've noticed that.
I thought I noticed the same with our V1!
I didn't notice the bass.
I did get the blgw updated though.
The automation on screen is nice.
Why use a touch panel from crestron for 5k when you can have a television there?
I like the automation additions.
How do you activate the automation menu on the TV screen?
v. Mikkel
I'm getting used to the "extra bass" but (after ages of not touching a thing) will have a look at the sound settings to put a notch down.
Do you have a beolink gateway?
If so, press the home control button on your beoremote one.
Voila
v. Mikkel
The New Beoremote 2.0 is on App store now!!
Has anyone tried the epg in the US?
Thank god! About time to get that facelift!
Along with my new found bass I'm actually enjoy my system alot more 😁
BeoVision 11-55....BeoLab 14 4.1....BeoPlay S8....BL 6000....BV8-32....BV6-26....Beo4....Beo4 Cinema....BeoLink 7000....Serene....BeoSound Ouverture....BeoGram 4500....H6 Bronzed Hazel....Form 1....U70....BeoLit 600...
