Beoplay M5 - sw 1.19.28681.3002866
My M5 has been updated to v1.19.28681.3002866.
Except for some minor text updates in the configuration interface I haven’t noticed any other changes.
Have anyone noticed any functional changes?
Best regards Dyssegaard
Interesting, mine had 1.18.27862 deployed on Jan 09 2019 and does not find any new update available.
What i interesting too is that I'm set for automatic update and the update log shows that 1.18 27862 was a manual one, which is not the really the case
My M5 was also recently updated to the 1.18 and shows as up to date.
How do you access the update log? I have looked for that but have nkt been able to find it.
Thanks!
In the product configuration main screen, select About then Diagnostics then Update logs (hopefully my french to english menu option translation works)
Thanks. I do not have a diagnostics option in the about screen. Maybe there are different versions of the app?
You have to go to the M5 parameters and then the configuration option that will connect you to the product configuration screen (French snapshot below):
Thanks! Found it.
The new software appeared today.
I think it added a new wireless network analysis feature under diagnostics? I do not recall seeing that feature before.
New software for Essence also. It also seems to have added the wireless network analysis feature. That feature is not present for my Core.
