Hiort wrote:
this might cause a bigger problem to your M5 instead of fixing it,
So funny .... which means that people that are not configured for automatic updates, nor have manually updated their M5 are in BIG TROUBLE !!! waw, scary !!! I updated my M5 several days after my other products and it was working (well) as before during this period
I fortunately don't have the message you have but I have had one issue so far, related or not to the update, it is hard to say as I think I already had similar case:
As usual, I pressed the M5 top to join the Core playing an Airplay source. No sound. Looking at the B&O App, the M5 had effectively joined the Core but no sound coming out the speaker. Playing with the hard & soft volume control had no effect. Going to another source like Deezer, DLNA or TuneIn was not successful either ...... up to a point sound finally came out the speaker without the need to restart it.
Looking at the logs, the M5 had a FPS crash and the FPS module restarted. Case raised, logs sent, I'll keep an eye on this.
