Beoplay M5 - new sw - 1.24.40904
New sw available for M5: 1.24.40905I have installed it and it works just fine. I cannot see any changes so far to functionality or setup menues.
Best regards
Dyssegaard
When I turned my M5 off, I noticed that my BR1 BT was updated. I then turned the M5 on again using the BR1 BT, and now I’m able to select Spotify directly 🙂: Login to view imageThis was not possible before the update. Previously I had to store Spotify in one of the MyButtons, if I wanted to select it with the BR1 BT.
Best regards
Dyssegaard
Might be an update for the other products as well?
Please report your findings!
Beosound 1 has got an update to!
No updates yet for my M5, Essence, or Core. Perhaps USA has yet to get the updates.
Same here. No updates to US.
I‘m in Europe and no update(s) up until now.
I’ve found this on the B&O support pages:https://support.bang-olufsen.com/hc/en-us/articles/360047320672-Can-I-hide-and-show-sources-on-my-Beoremote-Halo-I then changed the items in my local source list of my M5 (added bluetooth, optical, and line in) and after that, the added sources were shown in the music menu on my BR1 BT. The resent sw updates to M5 and other NL- speakers seems to have added this funtionality to both the Halo and the BR1 BT 🙂.
Best regards
Dyssegaard
I guess this is related to remotes updates more than product updates as the local list management exists since a while and is already leveraged by physical remotes such as the Essence remote, as well as by the clever Mac tool developed by TLKThe resent sw updates to M5 and other NL- speakers seems to have added this funtionality to both the Halo and the BR1 BT .
Nothing in UK as of yetI‘m in Europe and no update(s) up until now.
