Beoplay M5 - local control sometimes unresponsive ?
The local control on my M5 is sometimes problematic. Volume control (left/right turns) is always ok, but tapping in order to start/stop/change source is often unresponsive.
After power off/on everything is ok again as long as I only use the local control. However, when start to use the B&O app, the problem very often comes back.
Has anybody else had the same problem?
Best regards Dyssegaard
I have also noticed this. I thought at first something was broken, but then it worked again.
Doesn‘t really make much difference to me as I don’t usually operate it manually.
Tim
Tim
Thanks for your feedback. Good to know.
I will try to use local control and/or my Beoremote One BT with the M5 instead of the B&O app for a couple of days, to see if it’s the app that is causing the problem.
