I have been looking at the BeoPlay M3 to use as stand alone bluetooth/airplay speaker, but I would like to know what possibilities it has for future use.
As with many of the newer products it can be ard to keep track of the constant changing functionality due to software updates, and B&O's product sheets aren't to much use in that regard, and even with the information i can find on this forum it is hard to see the full picture.
so here is what I would like to know:
1) Does it have Airplay 2 with the newest software?
2) Will it work in a B&O multiroom environment with a BeoPlay V1 TV?
3) If so will it also be able to function as an integrated source for the V1?
4) And if so what limitations are there, for example will an airplay stream work and turn on the TV?
Thanks in advance
