Beoplay M3 dead: LEDs blinking... no reset, no reaction. Reanimation possible?
a Beoplay M3 died. Its LEDs are only blinking, Reset doesn't work, does not boot or react.
Is there any chance of reanimation or is it now a paperweight?
Bad news πŸ™
Did you try to play something through the line-in ?
What do you see exactly ?
Product indicator
– Off: Product is in standby mode or switched off.
– White (flashing): Product is booting up.
– Red (solid): Both Indicators turn solid red shortly before during factory reset.
– Red (flashing): Both Indicators flash red at the same time to indicate that software update is in progress. Do not operate the product or switch it off.
– Red (flashing): Firmware error. Disconnect the product from the mains supply and reconnect it.
– Orange (flashing): Indicator is flashing orange when the product is overheating and needs time to cool down.
Line-in: No.
Product indicator: Both LEDs are alternately slowly flashing white.
Factory Reset via button doesn't do anything.
I fear you're right about the bad news... :-(
During normal boot up, both leds are slowly flashing white simultaneously, not alternately.
β€”> you’d better ask the B&O support for the meaning.
And what about this?
https://support.bang-olufsen.com/hc/en-us/articles/360051064151-Setting-up-Beoplay-M3-using-a-web-browser
Asked a dealer alreay and he doesn't know what it means, other than it doesn't mean good news. ;-)
Tried it, does not work either, no "...M3..." WLAN visible. :-(
Tried an Ethernet adaptor which shows network activity but I can't see the LAN connection on my router.
Thank you for your help! :)
I'll ask B&O... maybe they have an idea or solution.
Hey there,
did you get any answer, which solved your Problem?
My m3 is flashing red and I can’t do nothing. :/
I did, several times but it stays in that red flashing mode.
Already pushed all available reset button etc. but both indicators keep blinking red.
I already contacted the support and they said the speaker is dead, offered me a 20% voucher...
I'm quite good at repairing stuff and already read alot about the amplifier board. Is it the same case with the M3?
Just replacing the amplifier board?
Thanks in advance.
