a Beoplay M3 died. Its LEDs are only blinking, Reset doesn't work, does not boot or react.
Is there any chance of reanimation or is it now a paperweight?
Line-in: No.
Product indicator: Both LEDs are alternately slowly flashing white.
Factory Reset via button doesn't do anything.
I fear you're right about the bad news... :-(
During normal boot up, both leds are slowly flashing white simultaneously, not alternately.β> youβd better ask the B&O support for the meaning.And what about this?https://support.bang-olufsen.com/hc/en-us/articles/360051064151-Setting-up-Beoplay-M3-using-a-web-browserProduct indicator: Both LEDs are alternately slowly flashing white.
Asked a dealer alreay and he doesn't know what it means, other than it doesn't mean good news. ;-)
Tried it, does not work either, no "...M3..." WLAN visible. :-(
Tried an Ethernet adaptor which shows network activity but I can't see the LAN connection on my router.
Thank you for your help! :)
I'll ask B&O... maybe they have an idea or solution.
Hey there,
did you get any answer, which solved your Problem?
My m3 is flashing red and I canβt do nothing. :/
Red (flashing): Firmware error. Disconnect the product from the mains supply and reconnect it.My m3 is flashing red and I canβt do nothing
I did, several times but it stays in that red flashing mode.
Already pushed all available reset button etc. but both indicators keep blinking red.
I already contacted the support and they said the speaker is dead, offered me a 20% voucher...
I'm quite good at repairing stuff and already read alot about the amplifier board. Is it the same case with the M3?
Just replacing the amplifier board?
Thanks in advance.
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
