Beoplay h9i "thump sound".
Hello.
I noticed that my pair of h9i's distorts when walking (bluetooth, anc on). When i walk at a faster pace and my foot hits the ground, there's this distortion/sound in the earcups (left one being more audible). With anc off it's much better but you can still hear it from time to time. Anyone here having same problems or found a solution?
TIA, regards
My son mentioned a similar problem. He reported it to B&O but didn’t get a satisfactory answer
keniutek wrote:
Hello.
TIA, regards
I have found the degree of thump depends on what type of shoe you wear. If you’re wearing a trainer with soft heels it’s not noticeable compared to smart work shoes. Your movement is amplified through your bone structure up to your ears which have been isolated by very powerful ANC headphones. This isn’t a technical fault.
It is poor design though. My sennheiser pxc550 nor beats wireless did this. I've just bought a pair of h9i and can't get over this. Happens on left more so than right. Trying the H7 pads....
UPDATE:  The H7 ear pads remove the 'thump' created by ANC :)
And they are soooo much more comfortable.  Why B&O ever changed these for the thin standard ones I'll never know.
Well, I do hope that you also provide this feedback directly to B&O to ensure that the next generation H9 gets on-track and better.
Can you show a picture of the difference? I also have the thump noise when walking with ANC and thought it was due to the in ear cup microphone and the air pressure change when walking and the headphones compresses a bit due to gravity and momentum.
I'm afraid that this doesn't fix it.  You can't walk heavily in shoes - better in trainers.  I'm going to report it.  Not good enough for such a high end model.
