My H9's do not have sufficient volume with my iPhone 6 Plus. When on air travel, hard to really hear content clearly. Any ideas on whether this could be corrected through software?
I bought a pair of H9 earlier this year specifically to use with the BV-14. I also thought the max volume was much too low and seemed to be limited by the BV-14 max volume setting in the bluetooth menu. The low max volume and an inability to reconnect with the BV-14 bluetooth even though it appeared paired meant they were returned within a month. A shame as they were very comfortable and had a lovely sound, just not enough of it !
Best Wishes
This is a Bluetooth issue. Connect the supplied cable from the H9s to your iPhone and hear the difference! I can't* listen to my H8s over Bluetooth. Just too quiet.
*edited - I accidentally wrote "can" before!
Yeah, use a cable with 500€ Bluetooth headphones to get them to work properly 😕
Erm, as I said - it's a Bluetooth issue not the headphones. But, hey, casually blame the headphones why don't you? Helpful.
No-one is saying that they aren't usable over Bluetooth. I know plenty of people who think it's plenty loud enough. For others, just not loud enough (and they want to damage their ears, too).
Well there is possibly a problem with using cable. I say possibly coz it might be the simplied cable isn't any good. Just got mine today and will invest in a high quallity cable before I make my final judgement.
Anyway. When I use Bluetooth I can't get it load enough, when I use the cable I lose all deep bass.
So I figured, haha, I'll just install the Equlazer APO and do a 12db preamplification of the signal.
But no, all that did was make the volume control do nothing from 50% to 100%.
I had this problem with some of my movies and the H8.
I am using now a Video Player called Infuse, that has the ability to boost the volume so that helped a lot. Note that for music I generally am fine.
Obviously that limits your sources, even though I think it might support Itunes content
I just bought a brand new pair of H9s (updated them to the latest firmware via the Beoplay app) and excitedly paired it with my iPhone 7 via Bluetooth only to find them to be very very quiet, even at maximum level they are just too soft in comparison to a wired connection.
really interested to know..
How did you with yours?
Did you contact B&O?
Not noticed this with mine. I play them around 66% volume and that is as loud as I need them. Wired is slightly (very slightly) louder but Bluetooth is good.I just bought a brand new pair of H9s (updated them to the latest firmware via the Beoplay app) and excitedly paired it with my iPhone 7 via Bluetooth only to find them to be very very quiet, even at maximum level they are just too soft in comparison to a wired connection. really interested to know.. How did you with yours? Did you contact B&O?
