Can't get sound from both earplugs, only the the right player!
Does any one have a suggestion to solve this?
If you have not done that, do reset of the earbuds.
To reset, touch and hold the left and right earphone simultaneously until the product indicator is flashing red (approximately 10 seconds).
Beoplay E8 will turn off once the reset is completed.
Thx Hiort. It did the trick ;-)
Glad it worked for you. Sometimes putting both buds back in the case, and take them out again also helps.
I rarely have the problem that only rigjht bud (who is the master) is playing.
Use mine on daily commute to / from work 🙂
