Beoplay A6 + DAC(OPPO HA-2) + Tidal
Good day,
before I spend any more money, I wanted to seek advice.  My present setup is Audirvana+2 + Tidal which I stream via airplay(many people will bash this setup but I have noticed that airplay streems quite well) to my beoplay A6 (I have not found a way to DLNA Tidal).
here is my question
Will I gain in quality if I use a DAC like the OPPO HA-2...? ( I am just worried that there is no way to by pass the Beoplay A6 integraded DAC).  My setup here would be Macbook Pro to OPPO HA-2 DAC via usb and Then Oppo HA-2 to Beoplay A6 via mini jack 3.5mm
If this is not a good option, what other setup would be better to stream Tidal.
thank you very much
indeed you might be right :-)
