My Beoplay A1 possibly stuck in Bootloader Mode. Does anyone know the fix?
thanks
thanks
Hi, have you tried reset?
To reset the BeoSound 1 to factory settings, open the Bang & Olufsen App and go to Settings. Click My Products and choose the device. Then, under the Configure menu, click Settings, Reset, and confirm Factory Reset to restore the device to factory settings.
