Hey there guys,
so i have a small problem with my b&o beoplay a1 after it fell down on the ground from 30cm height.
When playing music bass started to have distortions and makes “fart” noises. So i decided to check whats happened inside.
I disassembled whole speaker but did not unplug any wires or so. Connected it to a phone and played some music, and everything sounded superb, without any distortion or “fart” noises. But when i put it together distortions come again, i dont even need to screw everything back, just when i put upper part back distortions comes but when they are separate everything sounds great.
I tried to check if some wires or anything touching the main speaker or so, but it doesnt look like it. Maybe problems with air inside or something.
Maybe somebody knows whats going on?:)
I bought this speaker from B&O shop in Switzerland abroad and i dont have any checks from it so warranty wont apply for this one.
Thank you for any kind of help :)
