sia wrote:
Two questions,
1- can Beoplay A1 be paired with several Bluetooth devices. I'm of course aware that only one Bluetooth device can be used actively.
2- I know that it is possible to pair one Beoplay A1 with a Bluetooth transmitter. My question is if it would be possible to pair two Beoplay A1s with one and same Bluetooth transmitter (since I for instant can't install the Beolink software on a Bluetooth transmitter).
thanks
Sia
Hi Sia,
1. You can pair an A1 with up to 5 (I think) Bluetooth devices. But you can only listen to one stream (source device) at a time.
While you’re streaming from one device, you can open the B&O app from another device and check / configure the A1 via Bluetooth, e.g. check the battery level.
2. If your objective is to play the same music to a pair of A1s, then pair the source to the first A1 and start streaming. Then use the B&O app to connect the second A1 to the first. You can make the play a single channel each (left on 1, right on 2) or play the full signal on both A1s.
Hope this helps.
Lawrence
