Will the replacement belts from beoparts-shop.com (now: Danish Sound Parts) have the same issue or are they made of an improved rubber formulation?
Glitch
I do know that as long as the machine is used every now and then, causing the belts to expand and contract, that reduces the chances of “gooing”.I'd like to learn more about this. Can you provide any further details about why this would be the case? I've always assumed that the belts degrade due to a process (like oxidation) that either causes the polymers to break down (into goo") or form a "new/modified" substance that is less elastic (cracked, brittle belts). My motivation for having a better understanding of this is to help with a long term preservation plan for the equipment. For example, if it is inevitable that belts will turn to "goo", it might be prudent to remove them before placing the equipment into storage. An analogy would be removing the alkaline batteries from a vintage toy, draining the gas from an antique car that won't be driven for a while (or the swapping out the foam inside certain active speakers). I recently pulled apart a vintage computer where the CMOS battery leaked and corroded the nearby circuit board traces into green dust. Had I foreseen this, I'd still have a working computer. Glitch
