Beoparts-Shop Beocord Belts
It is well known that the original belts in Beocords turn into goo when they get old. Will the replacement belts from beoparts-shop.com (now: Danish Sound Parts) have the same issue or are they made of an improved rubber formulation? Glitch
I have been buying belts (and other parts) from Martin Olsen (Dillen) for over 20 years. One BeoCord which I still have, had its belts replaced in 2003. The machine still functions perfectly. I can't forecast what the belts would be like in another 20 years, but so far, I'm satisfied with almost 20 years belt-life confirmed on this machine. I do know that as long as the machine is used every now and then, causing the belts to expand and contract, that reduces the chances of "gooing". The other bonus is that Martin's belts have the correct tension, which does not cause destruction of the fragile sintered brass motor bearings in all these vintage B&O machines. Other belts sold on "e-ay" have a nasty reputation for destroying motors - very expensive repair, if at all possible.
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
All rubber belts will eventually wear out.  How quickly is determined by their use and operating environment.  The most important thing is to have faithful reproductions of the original belts which is what Martin produces. -sonavor
I'm certainly not questioning the suitability or performance of the beoparts-shop (now: Danish Sound Parts) belts. My assumption is that they are the highest quality part that is available. My question was related to a design choice. Material science has made great progress in the decades between when the belts were originally designed and now. The new belts could have been specified using the original rubber formulation or something newer. I wouldn't consider either choice to be "wrong". I'm just curious about which choice was made. Glitch
I do know that as long as the machine is used every now and then, causing the belts to expand and contract, that reduces the chances of “gooing”.
I'd like to learn more about this. Can you provide any further details about why this would be the case? I've always assumed that the belts degrade due to a process (like oxidation) that either causes the polymers to break down (into goo") or form a "new/modified" substance that is less elastic (cracked, brittle belts). My motivation for having a better understanding of this is to help with a long term preservation plan for the equipment. For example, if it is inevitable that belts will turn to "goo", it might be prudent to remove them before placing the equipment into storage. An analogy would be removing the alkaline batteries from a vintage toy, draining the gas from an antique car that won't be driven for a while (or the swapping out the foam inside certain active speakers). I recently pulled apart a vintage computer where the CMOS battery leaked and corroded the nearby circuit board traces into green dust. Had I foreseen this, I'd still have a working computer. Glitch
The transformation into the black goo is an interesting one.  I believe that happens due to the way the Beocord unit was stored.  I think a belt will wear to the point of requiring replacement during regular use inside a normal, home environment. I also believe the belts that deteriorated into goo happened because so many owners stopped using cassette decks (I know I did for quite a while) and put them into storage like attics, basements and storage sheds.  Those environments resulted in the deterioration of the rubber.  That is just my guess of course but I don't think a belt will deteriorate to that extent if the Beocord remains in use and is maintained (service checks). -sonavor
Not so sure John. I’ve recently done a VCR that had always sat under the TV set, until one day it didn’t work. The four belts had turned into goo, unbelievable. After hours of cleaning and belt replacement the VCR worked perfectly again.
Jacques
Poor storage conditions might accelerate the degradation of the belts, but I don't think that it is the primary cause of goo-ification. I bought my Beocord new and it has spent its entire life in a climate controlled, living space. Regardless, I ended up with goo. This issue is not unique to B&O. I've read similar stories for many other brands of equipment. The common cause has to be in the base material or in the manufacturing process of the belt. Who knows, maybe all of the goo-belts come from the same plant. I'm hoping that they have made progress on the longevity of the belts. I believe that they have improved the formulation for other issue prone parts like foam speaker surrounds. It would be a real shame if the plastics industry reserved the "forever materials" strictly for disposable items like water bottles and soda straws. (yes, I know that they are different classes of plastics) Glitch
I did a bit more research and found that the correct term for the phenomena is "rubber reversion". However, I think the term "goo-ification" is more fun ;-). There seem to be many theories about what is going on. Many of them are based on the supposition that the polymer stabilizing additives migrate out of the rubber. I'm having a hard time conceptualizing how a working the rubber would slow the process versus keeping it in a state of stasis. There is a group of vintage camera enthusiasts that swear by the "use it or lose it" theory when it comes to rubber parts on cameras. Perhaps the rubber should be considered a viscous mixture and working it keeps everything mixed-up appropriately? Regardless, I've already gone deeper down this rabbit hole than I intended. I'm still hoping that someone can shed some light on the original question. Glitch
I think the use it or lose theory fits here. Thanks for digging into the problem more. -sonavor
