BeoMusic app is merging with Bang & Olufsen app
Maybe already addressed in this threat but can the BLC be part of an multiroom session? I cannot include my BS3000 (per BLC) in a multiroom play session from my Moment.
If not, will it be included in short time?
Thanks.
I get the message "Action not supported by the selected product" whenever I try to play Deezer, TuneIn, or DLNA on my BLC.
Same here Jeff the app response is very slow and temperamental 🙁
Vince
same here. would be so great to see this working.
I experience this also.
One question. When my client tried to play using deezer in his favorite tracks. And try to skip the music, but it doesnt skip. It seems that the next button is only for the tracks in the play queue. Another question is that when you make products in multiroom, does the volume automatically is synchronized when you adjust the volume of the master then the slave will do the same also?
The last update introduced a problem when moving between access points.  The X app seems to get confused, at first it seems to forget that I'm playing music in multiple rooms, then it turns the volume down.  The lead ends up with a volume at about 1/3 of original and everything else is muted.
I have the problem with this app, anyone else has the same problem ?
- when you play the music from NAS , the CD cover is blurred even if you have the hi-res pic.
I don't have the solution yet. Any who know how to set up in the app or NAS ?
Same problems for me as well. Volume behaviour is erratic mainly because I use my moment in an integrated way with a beoplay v1 so the app gets a bit confused about which product's (the moment or the v1) volume to turn up or down. Moreover I have the same issues with the multiroom as mentioned above. My way around is to use the beomusic app. In the X app you have to turn the source local on and then try to add the blc. Then you have to turn off the source from which you play to your blc. If you then want to play an other song then the source (the moment in my case) will turn on again etc etc.
According to my opinion the beomusic app was much better and easier as a multiroom controller than the x app. In general it gave you a feeling that it is simple and straight forward. The x app seems quite complicated and as a result has not reached the right B&Oish level.
I agree with you. The X app is hard to use. The theme looks great but functionality wise its difficult to operate. Hope they can make manual for this and improve the application. I suggest put back the beomusic in the appstore since its the most convinient app for playing the B&O products.
