Hi everyone,
By the end of May, we will be removing the BeoMusic app from the App Store and Google Play Store. One of the major goals of developing the Bang & Olufsen app, was to reduce the number of apps we maintain and focus on making the best experience in one app. BeoMusic is the first to go. So, what does this mean for you:
- First and foremost, the app will not disappear from your phone, but it will no longer be available from the stores. It will stay on your phone until you delete it manually. You will, however, not be able to put it on new devices. You might be able to reinstall it using a local backup with iTunes.
- DLNA browsing will be ready in the Bang & Olufsen app when the BeoMusic is removed.
- We have already started on the dedicated iPad version and expect to have it ready this summer. In the meantime, you can carry on using the BeoMusic app if you prefer, or expand the Bang & Olufsen iPhone app on your iPad.
- 1st Gen BeoSound Essence (MK1) support is implemented with some limitations. DLNA and TuneIn favorites are not yet working. We are working on those and will have a solution ready soon.
- We have done the first tests with the NL/ML converter and work will begin in the next couple of weeks to support this in the app.
I know a lot of you are still using the BeoMusic app every day and it could be an inconvenience to change. You are probably also still missing some features yet to be implemented in the Bang & Olufsen app. But in long run we will have a more intuitive, cleaner and better app by making this change. Please bear with us until we have everything migrated, and continue to use the BeoMusic app if there are features you are still missing in the new Bang & Olufsen app.
Best regards
Thomas, Bang & Olufsen
