BeoMusic app is merging with Bang & Olufsen app
@djfairlay89: The volume problem should be fixed. Could you send us a feedback describing the issue your are experiencing
I am experiencing some unexpected behaviour, however it is probably designed that way.
On iPhone, when the App is launched, that is, either I am using it, or it is in the background, then the volume buttons on the iPhone controls the sound of my selected B&O product.
This is all fine and well when I am using the App, but when the App is in the background, and I am for instance browsing Instagram, the App should keep it fingers of the response from the volume buttons. When I find a video I would like to see, and turn up the volume to see it on my phone, the volume of the A6 also shoots up. I need to kill the app, before I start watching videos on my phone to only have the phone respond to volume buttons.
This is how it should work.
1. X App is active = respond to volume buttons.
2. X App is in background = keep hands off volume buttons.
When I have changed the volume on the phone with the app closed, and then open the app, the app also adjust the iPhone volume level, this also should NOT be done, the first interaction with the volume wheel should do this.
I know that the Now Playing screen is a cool feature, but there is to much overtaking of the phone from the App.
/Jacob
@Weebyx: This is a balance act and we will probably adjust it down the road. When the lock screen control is activated then we have the media session and also the buttons. We could make a similar option for the hardware buttons as we have for the lock screen. When disabled we never hook up the buttons, that might work.  When you start a video from the phone this should take over the media session and we should no longer listen to the hardware buttons. If this still turns up the volume on your product then it is a bug.
If the X App is launched but in background, and I use Instagram and control the volume, this also turns the volume of my A6 up/down. So I guess this is a bug ? Do you need some logs or anything from me ?
/Jacob
Testing the posted workarounds for:
"after removing and adding radio favorites, the app plays random favorites with random icons. Not the station you select"
On iOS 1.0 release version.
I can confirm, that if you follow these steps:
Clear the queue, close the app, restart the app, and wait for 13-15 secs in my case
the Tunein favorites appear and play as expected.
@Weebyx: Yes please create a feedback ticket and I will take it from there
MrAndersen wrote:
@Sandyb: We will let users chose what folder to start from. So now it starts from the root, that is why it shows the folders you list. In your case you can chose the music folder and you would get the artist, album etc. at the top level. We cannot do it automatically since this might be in a different language or you might have renamed the folders to something else. This is completely customizable
Thomas
I guess this is not yet in the current release?
Done... I have tried to write a way to reproduce it also, the forst time the app launches, volume buttons works as they should, the second time the app is active from background, and the put to background again, the buttons still control the sound of the selected device.
/Jacob
Uploaded logs earlier.
One other thing I've noted - which I'll monitor to confirm - my battery seems to be running down very quickly when X app open. I.e. Been in work all day today and x app open in background and now at 20%. I note that when I press volume for any other app volume is now going up on musi system - is this constant link draining the battery?
I just gave the new app a try. I am quite impressed. Much better than I'd anticipated. Great step forward and will even be even more once the missing feature will be added.
I am using the latest IOS (not beta), but ML/NL seems not supported yet at all. Is this still in beta? Any thoughts on my question below?
steve1977 wrote:
i have a question for those using the beta, which i read here already supports ml/nl: does the new app allow to play DLNA directly to the ML/nl?
