Finally had a chance to really play in the new App, using DLNA (Twonky). The app was snappy and pretty smooth. I think with a robust DLNA search added, it could be what I think I've been looking for from B&O. I'm still hoping for a potential new music system (not the Moment, not Essence) with all these features, so I can have a dedicated unit rather than use my phone -- but I'm not holding my breath.
BeoMusic app is merging with Bang & Olufsen app
I'm using the 1.0 iPhone version that came out yesterday. Other than the strange playlist with radiostations in it, I really like it.
But. I've found that suddenly after removing and adding radio favorites, the app plays random favorites with random icons. Not the station you select.
I've reported it via feedback in the app.
/ mike
I saw the same behavior with the (previous) Android app (didn't tried with the new release). I believe this issue comes from the sync between the X app list and the TuneIn list.If you have to modify your list, it's safer to do it from the TuneIn webpage.after removing and adding radio favorites, the app plays random favorites with random icons. Not the station you select.
Regarding TuneIn favorites: We are aware that there is a problem and are working on a fix. Since the product itself gets the favorite list from TuneIn they get out of sync. Two workarounds that might work:
- Clear the playqueue and start the favorite
- Restart the app, then we get the favorites from TuneIn again and they should be in sync
Sorry for the trouble
Thomas, Bang & Olufsen
Hi
I updated the app last night. I would love the app to have the ability to remove or add a selected few song to or from the queue. Right now you either renove/add one at a time or the entire queue/album.
Thanks,
Herr der Penguine !Love it !!😂Another little bit of good news for me: BeoSound Essence 1st generation is supported. It is my "Lord of the Penguins".Peter the biker
Sounds like my BeoLab 20's "going mad" problem which Thomas and have discussedHowever, when I open the X app the volume in the zone where I'm sending the stream races to max and even when the volume is decreased it shoots back up until the x app is closed.
