(New reply because edit doesn't work on Safari)
Holy sh*t, the podcast support is just what I was looking for! Shame it doesn't work the same on the Moment.
Understood, makes sense now, sounds perfect, thanks.
As for the suggestion below, the Go To Artist, and Go To Album options are brilliant in Tidal...think i've mentioned this before....
Also, as for Podcasts, fuller functionality would be a dream both in the app or on the Moment......though difficult to achieve i guess.....
The new app works fine for me, but my BS35 is still unable to find the TuneIn radios after having played something from "Music", albeit via Deezer or DLNA.
I always get the message "nothing to read" 🙁 and have to unplug/plug to the main to be able to use TuneIn again.
It's the same with the alarm clock function of course.
@CB: Sounds like something we should look into. Could you make a feedback from the app? Then we have the logs and your product info and it will be easier to help you
Just sent the error report via the app.
Fresh restart, played a Deezer song, then tried to play a TuneIn radio. Nothing to read. --> report.
As long as processing time does not impact battery life, response time and operability then any solution can be tried, but don't forget that some of us have large DLNA libraries (35k in my case) which means that any automatic processing must be a user choice.I don't know yet if we want to unify it. It is tricky. Would you want two album categories in your results, one for Deezer and one for DLNA? Or would your merge them together? When you start digging into this it becomes quite complex. At first I think we will split them up and then experiment with unified search down the road.
As my DLNA Video folder contains purchased music videos and rips of my DVD music such "Diana Krall Live In Paris" I would like to be able to play those media types so I can hear them even if I can't see them ... but I can live this being at the bottom of everyone-else's list: Login to view imagedidn't quite understand the first point re DLNA.....at present, the NAS shows Music, Videos, Photos.....whether that is a function of how my NAS is configured shouldn't really matter i think, as Videos and Photos are irrelevant to the app....
Exactly the same happens, if you try to use your NL-tv as the renderer for the movies/video clips.
That does not mean the use case is invalid 😎Exactly the same happens, if you try to use your NL-tv as the renderer for the movies/video clips. MM There is a tv - and there is a BV.
Login to view imageAnother little bit of good news for me: BeoSound Essence 1st generation is supported. It is my "Lord of the Penguins".
