? Which version do you have ?
1.0.0.6764 the IOS beta? Which version do you have ? MM There is a tv - and there is a BV.
Thanks.
Do you know when that will be out for us non-betas?
(I am (still) waiting for the iPad version, before I will switch from the Beomusic app.)
Hi Sandyb
Could you send us a feedback on this? Where does it freeze?
Thomas
I would if I could....but nothing responds...app opens OK, usually says Moment unreachable, but irrespective of that nothing responds, so can't even get to the feedback screen
1.0.0.6791 is out and may solve your freezing issue
Just got the new app (Android) with DLNA support - and it works!
This app is pretty great at the moment, I'd love to see you keep up the momentum. My personal wishlist is:
