Beomusic App (A9)
I know that the BeoMusic app is compatible with the A9 2nd Gen but has anyone been able to get it working with the first gen A9? Is there any particular reason why the app doesn't work for the 1st gen but the 2nd gen?
Firmin
Firmin wrote:
Firmin
Yes - there is a new (NL-compatible) hardware in the 2nd Generation A9.
Btw - welcome to the Beoworld forum!
NL compatible ... So this means I can select any source on the new A9 of my Beovision Avant or Beosound 4 via ML/NL convertor with the beomusic/beoremote app?
When the new SW is out, it should be possible to let the A9 (2nd Generation) be part of the NL.
Details/what will be possible will be announced then, I guess.
Note: there is no ir-sensor on the 2nd Gen/A9 - however, you can use the Essence Remote/wheely with it.
How do you have your BeoSound 4 connected ?
elephant wrote:
How do you have your BeoSound 4 connected ? The Essence of B&O is discretion in design and life
My Beosound 4 is connected with ML to the NL/ML convertor. At this moment I don't have an A9 ...
Thank you
