richtoy wrote:
I am now filling the 1.8TB data partition with the contents of my NAS to see how well the BeoMedia handles large numbers of files. I will be copying 4117 video files that reside in 249 folders (1.34TB), 16114 music files that reside in 1022 folders (149GB), and 5064 pictures that reside in 79 folders (6.84GB). It will be interesting to see how well it can cope with and index all these files...
How did it work out with the filling? I've played around as well and uploaded to the shared folder around 200gb music; approx 31000 mp3 files which worked out fine. Indexing usually takes a while since I previosly used a BeoPort solution. But, here I'm kind of turned off on the handling with the media files on the Beomedia 1. I've been trying to using the Beo4 including accessing the unit via VNC and I had my hopes that it would be kind of like working with the BeoPlayer interface as I've done previously.
Also I don't really see the point of syncing the BeoPlayer installed on a client with BeoMedia; it does a full re-scan everytime I start the BeoPlaer which in my case takes around 2 hours. I had my hope that I would be able to create playlists which I then would sync to the Beomedia which it doesn't. So for the moment stuck; guess that I'm doing something wrong here. Suggestions what to look at to get it to work proper?
