Beomaster 8000 volume panel wire
I have a stupid question...where is this wire going? Its loose wire on picture ground wire.
Best regards E[View:http://archivedforum2.beoworld.org/themes/hawaii/utility/beomaster 8000 photo WP_20160505_10_12_59_Pro_zpsdzek4gke.jpg:800:0]
It's going to the underside of the microprocessor board. Unfortunately I think it requires quite a lot of dismantling to get to it, as the microprocessor board is attached to the display board. Found a picture from when I was refurbishing mine.
/Dennis
Yes I had a look at my pictures before  took the panel off...but where on the back of the PC board...?
Thank you, all sorted :)
Best regards
E.
