Beomaster 8000 type1901 question / help
I myself think it has something to do with the headphone acting
like somekind of resistor because it connected directly to the
speaker inputs.
Therefore when removed from its jack resistance is lowered and current goes down as well.and by that getting too low.
pls correct me if i am wrong.
What impedance are your headphones?
Hi Martin, it‘s the bang and olufsen form 1 35ohms.
strange thing is that when headphone is plugged in sound thru speakers is good!
It's really difficult to guess at what you have done and what state your output amplifier assembly is in without any pictures. If you were working with the wiring on those boards you might have something connected incorrectly.
-sonavor
You‘re right, without pictures it‘s hard to say.
But having a hard time getting pics from my iphone to this forum.
anyways, went over the cables again and again because you are right, they‘re easy to mix up or plug em in the wrong way.
took out the right outputboard because i somehow expected the fault there sonewhere and guess what.
i missed a burnt trace, the one that is on the ground pin.
i soldered that and now everything is great again!!
a missing grounding can give these errors i learned.
Steven
Very good. Besides old capacitors needing replacement I have found the majority of the time that faults are some sort of connection problem. Either with a cable connector or some board trace ... or bad solder joint.
I'm glad it is working again. The Beomaster 8000 is one of my favorite receivers.
Thanks for every repky you and Martin gave. I have 5 of these
giant beasts 😍 i love em too!
3 of em now working again. 2 of em past the test of working almost everyday
for two weeks.
recently purchased a beocord 9000 as well and there are 3 beograms 8000/8002 waiting for
a little care.
