So I started with the Power Supply PCB (6) and followed the instructions from - link . Sure enough 6c35 was at 1.8nf. Replaced the voltage regulator also. Measured 4.9v on output. So that looked good but the system still did not come out of standby.
Two observations -
1. Anytime I disconnect the main power, I can hear relays clicking (off I assume). Good sign ?
2, At one point while measuring power across 6c35, the system suddenly came alive for a second..with relays clicking and display panel lights coming on. And then silent again...Checked all the fuses, just in case something blew but all fuses were fine. Not sure if anything else blew. (Yes, I have the Dim Bulb Tester on my to do list..I will complete that before switching on the system again).
Completed recap of Power Supply / Display / Microcomputer / Output Right. ESR meter showed 4 capacitors as damaged and majority of the capacitors were out of the tolerance values. There were couple which showed 5-6 times the original value.
After completing the right side, I moved to the left.
I started with the filter and tone control pcb. Removed the PCB and first step was to replace the missing buttons that Martin had provided. When I removed the PCB which the buttons press on, I found my three missing buttons - they had come out of their slots and were stuck between the PCB and front panel). The reason they had come out was because the PCB itself had curved. So the three buttons in the middle came out. (I have seen Beomaster 8000 for parts and also panels on ebay that have those buttons missing and used to think the seller tried to fix and failed and lost the buttons - This misconception is now fixed).
Login to view image
So the question is how do I fix the curve ? Without this the buttons wont work and will disappear again.
Next I started with the Preamplifier PCB. I found two capacitors (C115/C215 - orange) whose value does not match with the manual. As per the manual they should be 10uf/63v but on the board they are 10uf/25v. I don't think the system has been repaired. Which one should I replace with ?
Login to view image
I also noticed that some kind of lubricant has leaked from the damping system. (or someone tried to add it from the top or side). It is all over the left side. It's on the output pcb 5.
Login to view image
Notice the dust on the red connector on bottom right, there is no dust on the resistors below the damping system.(top right). It's all wet and shiny. Could this be the reason that system is not coming out of standby ? Fault-protection mode is activated ?
Any suggestions on cleanup process ?
I will be working on this board later this week.
